1,461 - 1,480 of 5,123 Posts
Discussion starter · #1,463 ·
Easy is no challenge....
Discussion starter · #1,465 ·
Called Summit about the shifter since it was suppose to have been shipped last week. Found out that was bs! Went off a little, but this is a TCI problem not Summit. Mentioned something about chinese contractor and the pisspoor service I'm getting. Apparently I was pretty close to the truth. Seems there is a Chinese contractor who does the engraving of the TCI logo and it is the problem. I told them I didn't need their logo engraved on anything and if they would ship it to me without the logo. I was told yes and they would ship it overnight. I received a $50 gift certificate from Summit. Now all I need is the ^#*#* shifter. I'm starting to get hot over this BS... Thursday I have an appointment to work on the exhaust. So this may turn out to be a good week after all.
Discussion starter · #1,467 ·
I just received an email from UPS saying they are making a deliver from TCI tomorrow. I'll believe it when it is in my hands. Probably missing parts..... TCI has me pissed off, I think I'll put a B&M sticker on it's side.
so salty.....:hide:
Discussion starter · #1,469 ·
I don't think salty is the word I'd use. But if TCI doesnt get their act together they will be out of business.
As long as you get your shifter I don't see how that's your problem :D hopefully it all works out for you :thumb:
Discussion starter · #1,471 ·
Yes, hopefully
Discussion starter · #1,472 ·
Success! Shifter has been delivered. Putting it on the to do list... Exhaust is next..
Discussion starter · #1,475 · (Edited)
I have an aluminum plate bolted to the floor for the current floor shifter. I'm going to build a short pedestal or box to sit this one on to get the handle exactly at the angle and height I want. The FastGate is just about two inches shorter than I want. I can reach it with the center console pulled up, but with it down it's a little awkward.
Discussion starter · #1,477 ·
Thanks, comparing it to the FastGate it is a nicer shifter with a better feel. But in all honesty not worth the hassle or the price.
Shifter mount suggestion:
I can make one for you, if you'd like.
Discussion starter · #1,479 ·
It's a little hard for me to see, but it looks like you having it mounted on a pedestal? That's too nice for Red, Mine will be more utilitarian, lol How did you run the cable? The cable run was the main reason I mounted the FastGate on the floor. This round I'm going to put it were ever it needs to go. Thanks for the offer..
Yup, 2 pieces of flat stock, plus a reinforcement plate under the floor. Welded those up to the rectangle stock, that have the angles cut into them. Bolts go through that removable panel and sandwich the floor boards. It is tilted in the rear so that 1,2,D are almost straight up & down. It falls right where your hand is while leaning on the console. Then I just had it powder coated wrinkle black. The hole in the floor is directly below where you see the cable go under the carpet. Just use a hole saw for that.
