With the 46RH conversion successfully completed. Redtruck is in need of a mod or two. Next up is to finally get her tune dialed in. Keith has been doing the heavy lifting and I'm trying to give him a platform that is easier to work on than the Manual flashed automatic based PCM. According to B&G the current pcm flashed to manual trans can have issues due to software and hardware not being terminated properly. Bought a 03 manual PCM from ebay and found it to be junk. Apparently locked up from security lacking compatibility with my truck. Can't tell for sure since I took it to B&G to have it checked and it was DOA. Still going to use it for a core for a new PCM I've ordered. Told the guy it was dead and had been opened but he said "no problem". Manual trans PCM are a fairly rare bird just to note the obvious. The good news is the same pcm is used in Ram 1500, 2500 and 3500. And the vin doesn't necessarily need to match the vehicle. I ran a salvage yard pcm for a couple years before I reflashed it with a vin. Anyway next mod, take the new pcm to [email protected]&G for him to adjust idle, rev and speed limiters. Install a pair of BV heads. Then tune the old girl. I bought one of those push rod holders, so hopefully I won't have the same difficulties I had last time. So that's the run down on Red it's all good...
