121 - 140 of 170 Posts
Discussion starter · #121 ·
So just an update, I ordered a pcm from "Flagship one". Best advice I can give anyone here is stay away from them. I got it in the mail and there weren't any kind of instructions. So I emailed them and asked if I had to do any special procedure. They said nope just plug it in and turn the key. So I turn the key and I get nothing. The dashboard lit up but that was it. No fuel pump, no guages, no starter....nothing. So I emailed them and the had me send it back. Their "techs" said my truck short circuited it and thats not covered under warranty. Which seems odd to me since the truck will start and run with the original pcm. Supposedly they're sending me another one or probably the same one. I'm guessing it won't work and ill be in small claims court. It was supposed to be preprogrammed and ready to run. Just plug and play with a "lifetime warranty"
Discussion starter · #132 ·
If I'm doing this correctly the top right hole should be pin 10. Which should be the driver for cylinder/coil 1. This is assuming that the top plug on the pcm is C1 but it doesn't look like it has a little insert in it for a wire or pin to make contact with
Discussion starter · #133 ·
Now im really confused. So just for $hits and giggle i tried the 2nd plug from the top with the orange stripe. Im assuming thats C2. I actually have continuity at the correct corresponding pin numbers for cylinders 1 and 6. How can that be? The 2nd plug from the top on the pcm can't be C1 right? I kinda wanna swap those 2 plugs on the pcm but they're clearly marked with color codes as to which plug goes where on the PCM and I dont want to burn anything up doing that
Discussion starter · #134 ·
So after a bunch of Google searches apparently C2 is the one I needed to test the pins at anyway so I guess that means my plugs are right and since I have continuity im assuming there HAS to be something wrong with the pcm. Whether it needs programmed or repaired
Discussion starter · #135 ·
Well I just got a call back from the dealer and they programmed the PCM and checked everything out as far as that goes and they can't find anything wrong with the PCM. As far as they can tell everything on that side is good. Some im REALLY confused. Im at a loss as far as where I go from here
