Hey guys new here, been checking this site out and never knew it existed and it's a bad *** site. Ok I have some questions, I have an 03 that I've been buying parts for building a front mount turbo setup on, but I've had a lot of health, work, and family related set backs that have held me from doing any building. Currently the truck has;
•Inertia 214/218 114lsa cam
•P&P milled performance heads
•Pro billet edge 3400 converter
•flexalite efan
•pacesetter long tubes
•03 trany mods line booster/tmr
-Best 1/4 of 14.2285@93.31
Ill give you a list of things I've acquired over the past year
•Two turbos GT4202 1.28 a/r hot side and a PT80 .96a/r
•Precision wastegate 66mm 7.2 psi spring
•Tial 50mm BOV
•Treadstone vertical flow intercooler
•4" Borla XR-1 muffler
•4.10 gears
•Cal-tracs
•4l80e still deciding on programmer
•B&M Stealth Pro shifter for ^
•Building all my own manifolds and intercooler piping
•I'm on a stock bottom end and I'm looking to run 7psi(w/g spring), what injectors should I run?
•should I upgrade anything else in my fuel system(I'd like to run E-85)?
•Tuning.... once I build my other engine ill be running a 230's duration cam cam, and have the 4l80e transmission, should I convert to a manual 05's pcm?(ive heard the iEMS-3 dosnt do well with big cams...
Any input from you all is highly welcome & needed!! I will be posting pics soon!
•flexalite efan
•Tial 50mm BOV
•4.10 gears
•Cal-tracs
