That location is where the water finds its way out. The trick is to find where it is getting in of course.
My first place to go is the third brake light assembly. Notorious for leaking defective gasket.
Pull that bugger off and check for wetness. Put a small bead of silicone sealant around the mounting hole and reinstall.
Others should chime in with suggestions.
Hope you can chase that source of water down.
