Just a note about using flex joint bellows and the install locations. I used a flex joint bellows assembly in the 2 1/2 hot side Y pipe. I've seen other turbo hot side systems built with a bellows style flex joint. Normally, I use a bellows internal with the wire mesh outer sleeve.
Well, early last week after doing the three 7psi boost test hits. Everything was running good. :smitten:
Started up the 05 to go down to get some stuff from the hardware store. There was an exhaust leak coming from the passenger header area. So, put the 05 back into the garage... :sad:
