Putting up some pics of mods done on the STS turbo kit to get this subject started.
Originally posted by Carrolls Ram:
Tim ran 9psi on his stock motor with water/meth and did like a 12.3. This is in a 5.7 jeep
Is this the reason why your truck don't run that good sometimes Austin?Originally posted by Carrolls Ram:
the boot has cracked and completely split. The boot that split goes to my IEMS3 and without a good vacuum reading the truck runs like crap.
Originally posted by NewBlue:
McMaster-Carr has most everything, maybe not the cheapest.
Hey Bill, I went to a larger 5/8" drain hose and fittings from the turbo. Also moved the pump closer and lower to allow better oil drain off from the turbo. Haven't had any oil back up problems since that mod.Originally posted by Ghost03hemi:
New STS oil pump, check valve and gaskets.
What happens to a regular vacuum line that is used under a boost condition?Originally posted by charged392:
Vacuum line and tiny zip ties works just fine for me
