So... what im hearing is cross my fingers i dont go on strike and put in a built zf8-hp70 asap.
rather than buying a built 8HP70 just get an 8HP90
and
I just ordered the 1227 trans dapt dual flilter relocation kit.
summit says it works on my 2008 ram but was out of stock
so i ordered from TDot here in Canada, as it "said" in-stock and was cheaper.
Now TDot is telling me it does not fit my truck, and is special order.
I told them to ship it anyway.
Im pretty sure Im right this time.
Just be conscientious, mindful of how you drive it with the RFE545, we all know it's time is short in your truck, it's going to get replaced no matter what with some thing better,(HP70/90), just remember the simple rules we've given you and you'll get a 6 maybe 8 months out of the 545.So... what im hearing is cross my fingers i dont go on strike and put in a built zf8-hp70 asap.
by the way the filters that you will need are Fram PH16 equivalent. I just give the Fram number because they're super common and easy to cross reference. the Amsoil filter number is EAO42 which is what I am running.I found the box and yes it is 1227.
perfect. i knew i'd have a new filter thread. but that makes it easy.by the way the filters that you will need are Fram PH16 equivalent. I just give the Fram number because they're super common and easy to cross reference. the Amsoil filter number is EAO42 which is what I am running.
i fortget, why did you rotate the alternator? you sent me pics.
Dan says he just got it installed in default location... I feel like hes missing something. but he hasnt tried to mound the AC yet.
