1 - 7 of 7 Posts
Discussion Starter #1
I started the truck today and it was idling rough with the ETC warning light flashing. The manual says to take it in for immediate service.
Is there anything I can check or troubleshoot from home? There are no trouble codes.
Thanks.
Discussion Starter #2
Thanks.
did it do it again after turning it off and restarting?
Discussion Starter #4
Yep. I tried a couple of times. I researched a little and I may have had some luck resetting the PCM or pulling the battery cables.
But it was raining and I am working the afternoon shift this week so I didn't have much time to play around.
I tried to drive it to the garage, but it was stuck in limp mode. I drove back home and called for a tow.
Hopefully will hear more tomorrow.
Easiest way is to pull the # 19 PCM skim fuse then replace, its marked in your fuse box and no hassle of pulling the battery terminals.
Discussion Starter #6
Well it ended up being a wiring issue. I read about a similar issue on DodgeForum.com. There is a wire bundle that runs along the fuel rail that is susceptible to vibrating and wearing through to ground out.
I don't know if it was the same wire, but I had a throttle control wire that was worn down to the conductor and totally grounded. The throttle was completely non-responsive.
So if anyone has a membership at DodgeForum, let them know they helped someone out here at HTC.
Good to hear you got it fixed. I have never heard of this particular problem and have had my wiring harness pulled apart and find it odd that it would wear through. Any pictures?
1 - 7 of 7 Posts
