I check the brake signal and seems to be working
Yes i can move the shifter but the transmission wont engage in any gear
Just stuck at P
Went to the parts store the other day and got the starter, apparently there are different part numbers for different years.....So you have to know what vehicle and year your transmission came out of, which makes no sense to me why they would do this......
have no clue what the differences are between the starters other than the part number, when I was in the store with the guy looking at the book. I went with what I was told my transmission came out of , 2016 charger/ Challenger parts fit.....I can't see there being any physical differences between the starters, they all bolt up the same (as far as the car transmissions go) and the engagement has got to be the same between the cars and the trucks because the flex plates are interchangeable, and the blockss are all the same. I highly doubt you will run into any issues not knowing the particular make/model your transmission came from.
I I have the exact same driveshaft coming... But I went to East Coast Driveline Inc. aka Long Island Driveshaft...PAT BROWN - SHOP MANAGER Very knowledgeable and also told me about a discount coupon code that would save me a few extra bucks which he did not have to do....Note the beautiful driveshaft. You're going to love that piece Mark, they build an amazing product.
the cover from a truck transmission will not work because the bolt pattern is different. the only thing that you can buy that will will bolt up to the block and bellhousing is a car oil pan, it is the same pan for the NAG1 and 8HP cars. However this pan is a front sump and will not work in a truck. you are going to have to fabricate something as there is not a bolt on option. this is the car oil pan, and you can see why the front sump is not an option on these trucks. at one point I did stumble across an aftermarket dust cover, but it was just a thin piece of tin that bolted up to the transmission to cover the lower half and did not bolt to the engine. i have never been able to find it again but it wouldn't be worth buying even if a guy could find it.I have been looking to replace the structural dust cover. With the research I have done it also says that the Dust Structural Cover - Mopar (53021491AA)will fit 545 transmissions and the 6 speeds, I have that structural cover that fits 545 transmission ,and I know that will not work. Does anyone have an 8hp transmission from a Dodge ram?
I have been using that plate for a long time with a newer style starter. I first converted because my old starter solenoid stuck out so far that it would interfere with the long tube headers for the eagle heads, where as the newer one had a much smaller solenoid and was tucked up right close to the engine block. I did a write up on here years ago about this swap and how I had to use the 8 speed plate as it is slightly different for the starter only.
I think I'm going to be able to provide better updates this weekend as I think I'm going to begin the swap. I went through my horde last weekend and I think I have everything to do this from start to finish. View attachment 51005
The truck parts catalogue lists it as a flywheel backing plate and it's just a thin piece of tin. I'm not sure it is actually required until I try bolting it up but I didn't want to get it all apart and then be missing just a simple plate if it is required.
I did not have one of those spacers in between my flexplate and crankshaft for my 545 transmission.. my flexplate for my 8HP 70 did not come with one at the time of purchase or was suggested. I suppose before I go any further I should hook the starter up and see how it engages on the flux plate.The truck parts catalogue lists it as a flywheel backing plate and it's just a thin piece of tin. I'm not sure it is actually required until I try bolting it up but I didn't want to get it all apart and then be missing just a simple plate if it is required.
fwiw I have been running the 8hp without it for almost 3 years without one and there haven't been any issues.I did not have one of those spacers in between my flexplate and crankshaft for my 545 transmission.. my flexplate for my 8HP 70 did not come with one at the time of purchase or was suggested. I suppose before I go any further I should hook the starter up and see how it engages on the flux plate.
