1 - 4 of 4 Posts
What is the difference between single and double din? what should I be buying for a 2007 1500 Hemi Laramie
Farrrrrr East Coast
the din is the size of the opening, 90% of all aftermarket radios are a single din, which is a 2x7 inch i believe, and a double din is a 4X7 inch. which is what most dvd players are, if you goin a double din you may want to buy a nav dash as the opening was designed for a double din, if you want a single din deck any brand dash kit should be fine, the issue is with the wiring,the truck dosent give you a 12v turn on, the proper way around it would be a pac harness, many of us just ran the 12v ignition wire to an external source or a 12vconstant and put a switch on it.
1 - 4 of 4 Posts
