1 - 6 of 6 Posts
· Proud Canadian
has anyone milled down their valve guides in order to install shorter seals? if so, how much did you cut down the guides and which seals did you end up using? any input is appreciated 👍🏻
I’ve been using cam motion kit vsk915326,
for eagle&6.4 there’s room up to 625 lift, over that lift,mill the guides another .060 to .080 and you’re good
pre-eagle, 6.1 top out around .580&.600 respectively, what ever you lift above those # + . 04 for safety.. .623 lift 6.1s would be a min . .065 to start.
reality is .100 is the safe bet.
comp cams positive stop seals for 09+ are also good, again mill roughly.10 off the top to start
· Proud Canadian
I dropped my heads off at the shop on Monday and told them to knock .100 off the guides, glad to get confirmation on it though. the seals I am going with are the comp cams p/n 516, do you have any suggestions on spring locators? ideally I would like to find a set that are .040 thick so I could use my existing shims.
Anything .660 to .720 Id will work, there’s a few out there as thin as .045, . Try Ferrea there $3.40ish a piece
· Proud Canadian
I checked out the ferrea locators, aren't they too big for the guide diameter?
1 - 6 of 6 Posts
