ShsuII, I know superjay and I can get a bit confussing at times. It's like my daughter trying to get me to listen to rap music. I don't understand a thing they're saying either. lol. I know this topic is quite long, however, its the day by day process of building a performance engine. We appriciate superjay's input. He's been building motors for 38 years. Denny is going into the Star Trek mode, of being, "In places, no man has ever been". In short shuII, we are taking a new, 6.1 short block, and making it into a 6.4. We will be using all the 5.7 parts, such as the heads, intake manifold and oil pan, etc. etc... The only 6.1 parts we are adding to the 6.1 short block is a modified 6.1 oil pump, cam and head gaskets. Everthing else is custom. The crank shaft, rods, pistons, rings, valves, fastners, fuel and timing contollers and on and on and on........ Oh by the way, the 5.7 heads have been EXTREMLY modified.
For your 5.7 motor with the 6.1 upgrades you have, you will also need:
#1 You will need Stu's custom mounting plate. If you have an 04 or 05, you will need to modify the right cylinder head for the EGR valve. Extend your fuel lines. I would throw the external valve dampners away, plus your valve springs, on your 6.1 heads and opt for the Manley goodies. Get those from Welded Hemi. You didn't say whether you had the 6.1 injectors and fuel rails. I'd get those also. I'd probably get the shorty wires from Art, to simplify the plug wire issues. I'm probably forgetting a few things, since the mod's that your doing are different than our's. Uniball would be the man to talk to on this one. It sounds like he is doing the same build as you.
