21 - 30 of 30 Posts
I checked GSM manual, you're right pins are the same, wire color is different. That just leaves the throttle. My 04 has the 03 style pedal with a cable to the box under the battery. Not sure if an 05 style could be installed?
On my pin-out I have the APPS signal #1 & signal #2 on the same pins with different colors.
Discussion starter · #25 ·
Thanks for this. I have used the +/- before I started using tow/haul and I have to say tow/haul responds and performed much more to my liking. Even in +/- there is still a slight lag in response of the truck. So I will keep it in tow haul constantly. How about on the high way is it ok to still keep the truck in tow haul?
I don't see a downside :dance: - charged392 mentioned earlier that it might well increase the longevity of your tranny too :thumb:.
:D
Which exact tuner did you buy? do you have a link?
Have an older Diablosport Trinity. Diablosport has upgraded their devices and I am not sure what the newer ones are called.
21 - 30 of 30 Posts
