1 - 9 of 9 Posts
'05 Boosted 426 & '14 4X4
will a Charger hemi fit into a Dodge ram RWD
Yes it will fit, but.... It will not run.
The Reluctor Wheel on the Crank Shaft has to changed in order to have the correct amount of teeth.
Then there is the PCM that could be an issue with a required programming.
Please pop over to the New Member Intro and tell us more. :)
there is a difference with the timimg cover and the organization of belt driven accessories between car and truck hemis.
you may have to modify the harness to reach new locations, extend AC lines.
OR swap the timing cover to a truck timing cover
with the timing cover swap would also have to swap all accessories as they go from 6 rib to 7 rib, with a different distance from motor offset.
i priced out all front end accessories from rock auto for around 700$ canadian. so about 500 USD. not including the timing cover.
1 - 9 of 9 Posts
