1 - 1 of 13 Posts
Purge valve is pretty simple. If you put a new valve in and get the same code then it's likely electrical issue in being a loose connection,cut wire or bad pcm. Passenger side where the harness runs over the engine in that lovely back corner make sure the wires are not rubbed thru the insulation onto the valve cover. Also make sure the wires did t get eaten by an animal under where the solenoid is plugged in by the battery tray there
Also welcome to HTC!
1 - 1 of 13 Posts
