41 - 60 of 74 Posts
· Gold-Member
:thumb::thumb:
· Greg
The saying was if you run 31" tire or larger use 4:56. If smaller go 4:10. I found 2100-2400 rpm at cruise was a good window for fuel and drivability. A short gear is fun to drive, but with high horsepower traction is a problem and you may find yourself looking for a taller gear. I use the words short and tall because we Americans often use High gear or low gear ratio to mean the opposite to their meaning. Example we will call a 3:55 gear a High gear ratio when it is actually numerically lower than a 4:56 gear which we refer to as a low gear. If you replace ratio with speed than it makes sense. Making a 3:55 a High speed gear and 4:56 a Low speed gear....
· Kevin
Thanks for the warm welcome guys! It's good to find guys local for help and not the whims of local shops...haha
So far what Fred and I have discovered about my Hemi...
Factory Options:
- Tow Package
- 4X4
- 3.92 gears
- Black leather Interior
- QC
- Sprayliner
- Sunroof
- probably more I can't think of...
Current Mods:
- Fred believes I have OBX LBs with Y pipe
- Flowmasters muffler (in place of cat), dual out
- Aftermarket 20" wheels with 33" tires
- Some kind of lift
- Aftermarket touchscreen Android with backup camera
- efan not hooked up (going to swap it)
- 180 stat
- AEM Wideband (need to install)
- Possibly TB ported (not sure, pics below)
- Some kind of Diablo tune (tried loading canned tune but got error when downloading stock tune as there was a tune already loaded)
Possible Future Mods:
- CAI (Fred may still have a BFI clone he had made)
- Taurus efan with DC controller
- Ported TB
- Magnaflow muffler (replacing FM)
- Maybe 4.92 gears (unsure if its worth it)
- Jay Greene tune
- CAM (Fred said Spartan is best for mid range power for DD...open to ideas)
- I'm sure there's more I didn't think of or could be recommended.
I don't really plan to run at a track...could change. Lol. I've just always modded my vehicles since I was 17 so its in my nature. Still have to decide to what degree I want to mod.
First goal is obviously getting bolt ons situated. After that its up in there air.
Nice truck! Welcome to the Hemi Truck Club!!
Discussion Starter · #51 ·
Thx man! Yeah I understand the correlation between tires size and gears. I've got 33" I believe...last time I did the formula. Not sure what size I'll eventually go to but the truck is lifted now so 28"-ers aren't in the future...haha. Once I get the 4.56s done, I'll just make sure the tire size makes sense moving forward.
Discussion Starter · #52 ·
As for mod updates, I have installed a 180 tstat. Man did that take way longer than it was supposed to. Makes me want to drop the lift that came with the truck. I had no leverage up there.
Also had the little FM muffler swapped with a 8X11X22 Magnaflow. Sounds better/quieter/no drone, and apparently better flow. So multiple wins there.
More immediate next mods will be a Taurus efan and gears (hopefully I can find most parts from forums members).
I still have stock intake and probably should put that on the "next" list but I'm stuck on wanting the ever elusive BFI/ramhammer intake, so haven't pulled the trigger on any other more common ones...lol
· Mark G Senior Member
05 Ram 5.7 Turbo Charged
Your stock intake actually gives you more torque so don't sweat that... As long as you're not trying to pump 20 pounds of boost through it you're good...
· Greg
Can always drop a a Afraid filter into the stock air box. They even make a pipe to eliminate the hemi hat.
Discussion Starter · #55 ·
Didn't know that....glad I didn't just get one because everyone's doing it...lol
This may be a good alternative...from what I understand the hemi hat is the main restriction in the stock intake. So eliminate that with a better filter and should help breathing, yes?
· Greg
That's the one I was thinking about, but it is more expensive then I remember. Maybe try ebay..
Discussion Starter · #58 ·
How it seems to go...test the market with lower costs then with popularity, jack the prices up...lol.
Looks like something that should be $50 shipped.
Wish I could somehow fab up a 6" to 4" BFI style intake.
41 - 60 of 74 Posts
