161 - 180 of 2,905 Posts
Discussion starter · #163 ·
Guess what guess what my stalling is gone haha must of been something in the trans causing it did the swap without disconnecting battery so memory and idle wouldn't be lost and for two days now no stall in the morning
A quicklearn is a must Keith... Otherwise that trans might be short lived as well
Discussion starter · #166 ·
Yes I did filled with fluid heated her up idling backed out and did a quick learn
You forget I had done this 10 times before and I am an ASE master tech
Emailed Denny and asked what filters to use said use 4x4 filters and I asked About break in time he said as long as it shifts fine and fluid is good there really isn't a break in period he said take it slow so I'm going to put 1k on it then slowly lean on it more and more
Discussion starter · #168 ·
this is the pipe lenght from center of axle to where it will reach on the truck 19" farther forward than lead leaf eye this pipe is very strong i dont think i will be bending it at all
Discussion starter · #169 ·
here are some mcgauphys shop drop brackets the center part is to narrow to slip on frame rail so i am going to cut it out and use a little bigger piece to attach it to the frame will be bolting it on and then tacking it in place they work perfectly the bar will sit about 2" off frame now all i need to do is bring truck to a chassis shop and have them weld ears on the axle tubes for me to mount it up and then i am done
Discussion starter · #173 ·
This is why I went long bar instead of caltracs with the bar directly under the axle and perfectly parallel to truck there is virtually no bind in suspension just twist stop when wot the axle really only moves up and down with my single bar setup and only transfers torque thru bar when really hard accel occurs I drove in a lightning and you couldn't tell at all by when he stabbed it all it did was spin no wheel hop any more we will see how it goes and they are adjustable lh/rh thread so at track I can preload the hell out of them
I've never felt wheel hop on my truck either
