Mods in motion
1 reading
228K views 2.9K replies 48 participants last post by  charged392
#152 ·
Originally posted by VA4MEDS:
Speed shop in Jax cuts 1 end of the track bar and welds up nuts & threaded rod for adjustment, lock nut & aligns to true center roll for $150.
I read that this week on another site. Now I just have to find it again.
I was bored.
click
They also cut and rewelded his anti-sway bar end links to level it back out after the drop for that price. I've already done the same thing to my endlinks. I'll be heading to Jax for this one when I lower the truck some more and need another alignment.
#153 ·
Well got super slammed today at work I am currently in the middle of two evaporator jobs and there's a third in the lot waiting to go I love the work but would like to put my trans in tomm hopefully anyway pics to come
also ordered my Heims today from eBay gotta love that site 8 Heims with lh/rh thread and weld in bungs for 80$ that's a steal picking up 1" x .120 pipe sat and then waiting for mail to start this is going to be awesome
#166 ·
Yes I did filled with fluid heated her up idling backed out and did a quick learn
You forget I had done this 10 times before and I am an ASE master tech
Emailed Denny and asked what filters to use said use 4x4 filters and I asked About break in time he said as long as it shifts fine and fluid is good there really isn't a break in period he said take it slow so I'm going to put 1k on it then slowly lean on it more and more
#169 ·
here are some mcgauphys shop drop brackets the center part is to narrow to slip on frame rail so i am going to cut it out and use a little bigger piece to attach it to the frame will be bolting it on and then tacking it in place they work perfectly the bar will sit about 2" off frame now all i need to do is bring truck to a chassis shop and have them weld ears on the axle tubes for me to mount it up and then i am done
#173 ·
This is why I went long bar instead of caltracs with the bar directly under the axle and perfectly parallel to truck there is virtually no bind in suspension just twist stop when wot the axle really only moves up and down with my single bar setup and only transfers torque thru bar when really hard accel occurs I drove in a lightning and you couldn't tell at all by when he stabbed it all it did was spin no wheel hop any more we will see how it goes and they are adjustable lh/rh thread so at track I can preload the hell out of them
