Mods in motion
1 reading
228K views 2.9K replies 48 participants last post by  charged392
#1,338 ·
How about pulling a diesel trick and plumb the exhaust with a pyrometer. This way you have an idea of what temperatures you have.
#1,341 ·
Since you are all forged, if you knew what the pistons can stand. Then you could max tune it on the safe side. Might be really interesting to see what they can safely stand. Just saying...
#1,342 ·
Stu, can you change heads using studs with the engine in the truck?
#1,343 ·
Yes but a lot hotter air than what I will be running shortly due to maxing blower out.
Stu I have had studs since the first pop 3 years ago and still blew them out studs won't stop detonation damage I don't care how tight you have them clamped down.
#1,345 ·
Does it make sense to stud a stock piston motor on low boost?
#1,347 ·
The studs only replace the long bolts, right? What's the thread size for the studs? 12m x 1.25? Looking at what install tool is needed.
#1,349 ·
Since I'm changing heads, seems to be a no brainier. What do you torque the long studs to? 110 ft/lbs?
#1,351 ·
Thanks, enjoy your evening....
#1,353 ·
I was on the verge of building a motor when this opportunity presented itself. So I'll go this way and not push the envelope. Even turned down this should get me some respectable numbers for being a street truck...
#1,355 ·
That's the plan, will adjust my shift points down some. Should be interesting.....
#1,357 ·
You'll need water/meth and a good intercooler.......
I've gathered some bits & pieces. Will trigger the wtr/meth with a pressure switch I had left over from the previous install kit where I used a vacuum switch instead.
#1,358 ·
Ok new blower is on the way old blower will be coming off this week Wednesday I hope and be set in a box ready to go north!!! Metal will also be here Wednesday and have the bracket made up for the kit also. Gotta send a lot north but it will be worth it once done for the both of us.
#1,359 ·
Sweet! can't wait to this thing run.....
#1,361 ·
I know exactly how you feel. Along with SC I've installed the API BV ported heads. So Red is getting a double upgrade.... :brows:
#1,364 ·
:thumb::dance:
