61 - 80 of 2,905 Posts
Discussion starter · #65 ·
Oh man am I s.o.l.
Called ATF today and asked about quotes I had dent received yet and was told they can't build a trans for my power level just 450 area they say it's the tuning side I told them I had tuning under control they gave me the runaround basically saying nope multiple times so now I'm really stuck do I go with a sharadon or do I take my spare in the garage and get the eagle clutches and steels with a transgo kit offline and order a stronger converter it would cost 1200 that route or should I just keep melting transmissions
If anyone has any ideas help I'm not against manual trans either keisler makes an awesome trans no clutch needed once rolling that would be good for the track
Help need advice
Maybe ATF has been having problems with our 545RFE transmissions. Then I would say Sharadon would be your best bang for the buck. The other transmission, computer, trans adapter, ect, ect, will cost you big bucks. Or, you could go with a Turbo400 trans. Their very strong. And you can get all kinds of performance parts for them. But, you might have to do a stand alone computer on the engine. Most people just go with the Sharadon. I think that they have a stage 4 trans now.
Notes: If you do go with the Sharadon trans, get the Edge Pro Torque Racing Converter with the trans. You must drive the truck around to break in the clutches. At least 1200 miles before you stomp the gas. You'll have to trust me on this.
Discussion starter · #69 ·
Ok I will have to call them then tomm maybe if I have time
1200 miles is alot but I'm fine with that I probably shouldn't use the converter I have then either I need a new one
id kill to have a th400 in mine. Trans break + 4x4 launch... Probably need eyeball braces.
Or u could do the stand alone setup. Like FAST XFI then a stand alone controller for a th400, or a 4l80e which is basically a 400 with an overdrive.
But Josh's truck ran good with the sharadon stage 2 that he built on the phone with Jerry and Denny and Sharadon also had one of their trannys behind KORE's baja truck and it didnt crap out
How many trucks are still running the fully built Sharadon trans with no problems?
My trans still slips in 4th gear while down shifting 60-70mph in tow/haul mode. Down shift into 3rd with the tow/haul mode off, and it takes off like a rocket. But the Sharadon trans is made for track performance. And that's where it truly shines.
Try not to do down shifting with WOT with the overdrive still on. The clutches will last longer. One of my other favorite things about the Sharadon trans. When you drive normal on the street. It shifts like a stock trans. Doesn't slam into the next clutch when shifting on normal driving.
Good solid shift at WOT. Not slamming shifts like you would get with some of the other shift kits on a different trans.
Keith, let Sharadon build your trans. Don't do it yourself. Trust me, it's better that way.
And make sure you get nothing but the best Edge T/C. Sharadon does their trans builds using the Edge T/C. A 2800rpm stall is a great all around T/C for our trucks. Don't go anything bigger than a 3000rpm stall. There are some trans computer problems there with our trucks. Especially if you plan on driving the truck around every day. When I had that bad Edge 3000rpm stall T/C. It mad me think that the trans had a shifting lag or clutch drag problem. It wouldn't shift right. That's why I sent the bad blown up T/C and the trans back to Sharadon for a full trans and clutch inspection. They did have to replace some clutches and the T/C.
And did they say if they have a stage 4 trans??????
I know Darell with the 392 turbo has one thats running strong. Everybody jumped ship and went with ATS since they have their warranty but you pay over 1g more than a sharadon one and get pretty much the same thing.
I read that they had a stage 4 in the works awhile back and i'm sure now they have one.
You're exactly right on the treatment of these transmissions though Stu. Dont ever do a WOT downshift from anything over like 20mph. I know ever since Dave tuned my tranny the trucks drivability went WAY up since I can actually accelerate in traffic from a roll. Little gas and it downshifts into 3rd instead of 2nd prime. I think I've only done like 3 WOT downshifts with this truck and that was back when it had 500 miles on it and was all stock
mine was a different Sharadon.... It was a Stage 2.5 Trans with a Stage 4 VB lol..
Had no problem Building it in my Garage.
Discussion starter · #78 ·
Going with a stage 3 in 2 weeks have house taxes to pay first called hem today 3400 or so shipped then get core back and I have to order another edge converter and she's good to go
No downshifts for me at all one wide open from a dig or cruise normal I'm not waisting my money any more caltracs soon to follow and then slicks still need one steel wheel for another slick after that look out
I have been told with my 60' and mph in 1/4 I have a high 11's truck so let's see boy this is going to be a fun year
Discussion starter · #80 ·
Thanks rim will deff help
Trans is two plus weeks away for me I'm going to try and get caltracs at the same time but don't know if money will be there or not saving my ass off right now I'm down but not out
