Keith, are those air shocks on the back?Shocks repositioned susp feels alot stiffer in the rear now I like it better this way now to get bar mounts redone
It would spin the axle easier under load and suspension squat at 0 degree. Not to mention, how much harder it's on the u joints at 3-4 degree's on a heavy load. Just trying to help you get your truck into the 11s Keith. Every little bit helps.:thumb:pinion points upward perfect angles under load about 3-4degrees diff
:whistling::ermm:heard this guy making allot of noise, changed both of them for good measure
