Mockup install just sitting in there with rails on need to redo wiring harness the factory manifold clips no longer work and will have to extend map sensor plug its underneath manifold now in back
Not sure I'm betting a couple for sure the factory intake had to be a little restrictive for sure will never know exact hp added never did get to a dyno with built motor and old intake all I know is truck made 410hp and 418 torque with stock eng on 6lbs with current build and 12lbs haven't got a clue
Well extended the wires for the map sensor today and routed the harness a little better once tapped and loomed will look good
Ran into a snag trying to fit the intake hat on the motor it won't fit forward with a 1" spacer or sideways hits the coils (was designed for car coils or jeep with no wires) ordered a 2" spacer on eBay will slow the adapter to be mounted sideways and run pipes under ac lines and around don't think I will make the midnight drags this may take a little fabrication work
Will also need some 3" aluminum pipe to connect intake bake together it will be very cool once its done a complete 1 off intake setup for sure going to also try and have all the pipes welded in pieces as long as possible to eliminate ugly clamps will keep you guys posted its a little bit more work than originally thought but it beats a blown eng running it how I was
A forum community dedicated to Ram Hemi powered truck owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
