Originally posted by Carrolls Ram:
But Josh's truck ran good with the sharadon stage 2 that he built on the phone with Jerry and Denny and Sharadon also had one of their trannys behind KORE's baja truck and it didnt crap out
How many trucks are still running the fully built Sharadon trans with no problems?
My trans still slips in 4th gear while down shifting 60-70mph in tow/haul mode. Down shift into 3rd with the tow/haul mode off, and it takes off like a rocket. But the Sharadon trans is made for track performance. And that's where it truly shines.
Try not to do down shifting with WOT with the overdrive still on. The clutches will last longer. One of my other favorite things about the Sharadon trans. When you drive normal on the street. It shifts like a stock trans. Doesn't slam into the next clutch when shifting on normal driving.
Good solid shift at WOT. Not slamming shifts like you would get with some of the other shift kits on a different trans.
Keith, let Sharadon build your trans. Don't do it yourself. Trust me, it's better that way.
And make sure you get nothing but the best Edge T/C. Sharadon does their trans builds using the Edge T/C. A 2800rpm stall is a great all around T/C for our trucks. Don't go anything bigger than a 3000rpm stall. There are some trans computer problems there with our trucks. Especially if you plan on driving the truck around every day. When I had that bad Edge 3000rpm stall T/C. It mad me think that the trans had a shifting lag or clutch drag problem. It wouldn't shift right. That's why I sent the bad blown up T/C and the trans back to Sharadon for a full trans and clutch inspection. They did have to replace some clutches and the T/C.
And did they say if they have a stage 4 trans??????
