661 - 680 of 2,905 Posts
Discussion starter · #661 ·
Fine with me yes it is to be made of 1/4 inch by 2 inch flat steel or 1inch tube with a .180 wall I believe and it has to be no more than 6inches from front yoke (even though they never snap there)
I have the steel drive shaft In my truck I will need to know the diameter of the qc shaft to make one for you bill its a bolt in will need 2 holes to mount it up
Good job Keith.:thumb::thumb:
What's the requirements on where the drive shaft loop is placed?:confused:
From the NHRA handbook: all cars in competition using open driveshafts must have a retainer loop 360 degrees of enclosure, 1/4-inch minimum thickness and 2 inches wide, or 7/8-inch x .065-inch welded steel tubing, securely mounted and located within 6 inches of the front universal joint for support of the driveshaft in event of U-joint failure. Open drivelines passing any part of the driver’s body must be completely enclosed in 1/8- inch minimum thickness steel plate, securely mounted to the frame or frame structure. Driveshaft loop required on all cars running 13.99 (*8.59) or quicker and utilizing slicks; except vehicles running 11.49 (*7.35) seconds or slower equipped with street tires.
That was nice launch!
Discussion starter · #675 ·
Things to try to go faster !!!
1. Tape shut 3 grill sections to limit wind interfearance thru eng bay
2. Install susp limiters thru old sway bar link holes
3. Let Becca drive (every other car I have owned she went faster)
4. Add a DEI CRYO2 kit later on
Discussion starter · #680 ·
Well go to thinking today about the trans cooler always wanted a bigger one then it hit me like a Brick just take the 4x4 cooler off the black truck we don't use it for towing anymore so it's fine without it and switch them out walla bigger cooler and completely free
