Mods in motion
227K views 2.9K replies 48 participants last post by  charged392
#713 ·
Nozzle location directly in front of the throttle body doesn't get any better
Went out and did a little test run had no traction in 2nd shifted to third let off then back in it and 3rd just spun like crazy I have never had traction issues for the most part at 80+ in third till today will do a little more testing tomm but dial it in the 2nd
#715 ·
Sweet!
#714 ·
Looks good, I use my washer bottle which is good because it has the empty indicator.
#720 · (Edited)
Meth is gooooood!!!!!:D:thumb:
The W/M will also help keep your throttle body, intake manifold, intake ports, intake valves, combustion chamber and piston crowns cleaner. Better performance all of the time.:thumb::thumb: And will help stop that nasty word that all engine fear.... Detonation!!!!!:eek::eek::eek: Helps save pistons too..... :whistling::whistling::whistling:Oooops, the secret is out.:facepalm:;)
Now we need to get Bill's truck addicted to meth.:D Turbo's LOVE Meth.:brows:
#724 · (Edited)
Yeah it helps on all motors but will also allow na to run more timing hence more power
Meth is basically a race fuel that's injected cooling the air charge while raising the octane
shhh you are letting all the secrets out....
Would either of these work on my N/A very mildly modded HEMI.
Snow Performance
Nah, it'll ruin your engine!
I'm lying.... :coolsmiley:
The one I'm using I believe is discontinued. Mostly becuase it was a little tricky to use. I have a rpm window switch to arm it and a vacum switch to trigger it. The problem being on a na engine is the switch is set for low vacum, with the ign ON and the engine not running it is below the vacum set point (ie no vacum) and the system would activate. Arming the system using a window switch would leave the system turned off until the engine was actually running.
Like I said that system is no longer available and a much better system is now being offered in it's place IMO. http://www.snowperformance.net/stage-2-boost-cooler-n-a.html
Good luck you will like it. Day to day running you can use -30 windshield washer fluid, Boost Juice and finally Nitro Boost for a night out.
#725 ·
#734 ·
Good news going to be adding something I swore I would never use ever but with the octane increase the meth gives me I will be able to run the same timing and gain alot of power too will be using a dry shot since I will be able to increase fuel pressure a little anyway if I hook the regulator line back up testing will be fun for sure
This will for sure get me in the 11s with a really cool air charge air substantial power increase
#736 ·
Correct me if I am wrong but I thought Dry Spray Nitrous was bad for our trucks????
#738 ·
Going lean is bad for the engine. If the proper A/F is maintained then the method of delivery doesn't matter.
#741 · (Edited)
Well NOS is out not goin to suck the bottle instead found something better I can upgrade the impellar in the blower to the billet 928 motorsports one and gain 1-3 psi from its efficiency and still use the pulley I have
7.25/3.5=2.074*6300=13,050*3.5=44,950 currently 6 k from max blower rpm new impellar allows up to 60,000 rpm givin me the ability to run a 3.25" now if I wanted to putting the factory impellar close to its danger zone or with billet I could run a 2.75" pulley and that could get me close to 17-20 psi of boost from a novi 1200 that's sweet the methanol is going to be very useful here shortly
7.25/2.75=2.636*6300=16,609*3.5=58,131 with 2.75" pulley and billet impellar no nitrous for me and 11s for sure provided rear holds up :)
#742 ·
You will likely find the small belt will limit the maximum boost, even with a modified belt tensioner. At least our trucks are 1 rib wider than the Hemi cars use. 17-20 psi is in cogged belt territory.
