Keep a eye on your coolant level, white smoke is a indicator you have water in the combustion chamber.Originally posted by Ghost03hemi:
Completed testing for crankcase pressure. Had almost 2psi crank pressure at 10psi boost(10.5boost spring and W/M set correctly). Note: I don't know about your truck. But, my truck started smoking white. Uncapped the intake manifold breather tube. And the white smoke cleared out. PCV valve test sat.![]()
In your opinion, why do you think this is happening?Was expecting more pressure/blow by from the rings
Yes...Originally posted by Superjay:
Do watch your oil level, Keith.
The cross hatch(220 grit) and pitting is holding some of the oil on the cylinder walls for better lubrication and ring sealing. At least, that's what I hope is happening.Originally posted by Superjay:
