1 - 6 of 6 Posts
Hello everyone.
It seems that I am losing break fluid, but I do not see a leak anywhere. I will be going over everything again just to make sure I didn't miss anything.
I read somewhere that there could be a leak into the Master Cylinder. Is this possible? If so, how do I verify it?
Is there anything else I can look into first that may be the possible cause?
Any help is much appreciated. I have gotten a lot of help from member here, just wanted to say thanks.
'05 Boosted 426 & '14 4X4
I have strategically placed a white paper towel in locations to help me find a Brake Fluid leak. Gotta know the source first. Not fun chasing that down.
Are you loosing brake pedal, traveling to the floor, spongy, or is the brake fluid level dropping?
Thanks for the reply. I haven't been able to jump on here in a while. It did seem like I was loosing the pedal, I would have to pump it when the fluid was getting low. When I fill it up, I get the pedal back.
Was finally able to find the leak. Found it while changing the oil. The leak was coming from the Front Drivers Side caliper. It was a really small one which is why I probably missed it before. But I changed the caliper out and will keep an eye on it.
1 - 6 of 6 Posts
