The relay will get hot. Feel some of the relays in the box after 20mins of running they will be hot. You should be able to hold it in your hand issue free but it will be warm
Yes, it does. The pcm isn't happy after a 14psi test hit. Normally, it will idle rough and the pcm will adjust back to the original settings and all is good. Add in 2psi lower fuel pressure and she's pissed off running very rough and very lean at idle. That's why I have to get this fuel pressure problem straightened out.does it matter that your idle pressure is a couple pounds low?
--------------------------------------Thats why i love our old trucks, we can do whatever strikes our fancy regardless if it makes sense to anyone else..
