ill have to use your how to on an 09, we have done a 370 stroker, blower cam, magnison lung, all the typical bolt ons and just added nitrous. (150 shot) we have maxed out the blower at 11 PSI (smallest pulley they make) and we are at 520RWHP and 545TQ, (no nitrous) the motor is starving for fuel, and its not due to the pump we upgraded it already. the fuel lines are too small. but since we already have aftermarket fuel rails, we will need to go slightly different than what you have done. we will need to tee off the back of both rails, on the supply side and then t the fronts out to a regulator. and then back to the tank. we will be puting the return line in the basket as even with the pump we have now, and the fuel lines, it will.do as you said and cut out when the tank gets low. im actually thinking about fabing up a new basket so that it will eliminate this.
