1 - 20 of 41 Posts
Ariel
My trans finally started to slip so I decided to go with the 46RE swap. I just ordered a Martin Saine transmission with controller that im hoping to get in a couple months. I cant wait. So I want to be prepared and have as many parts possible for a smooth install day. Martins sending trans, converter and controller. What else do you guys think Ill need? Im looking at B&M shifters. Any recommendations?
Reactions: ATXHEMI
Ariel
Reactions: Redtruck-VA
Ariel
This was the other option and adding toggle switches. You think its better to go with toggles vs adding the relays?
Ariel
I was thinking about it if the buttons dont light up when engaged i might not remember while driving if the buttons engaged. Maybe adding an LED light would work.
Reactions: arocketman
Toggles are easy you just have to flip them off every time and on. The buttons make it convenient so you don’t have to move essentially. We could add lights so when they are on you will know.
Ariel
Discussion Starter · #8 · (Edited)
I really like the stealth one but they dont have it with the two buttons so i got the one with the buttons. When I get it i’ll dissect it and see if i can change the switches to latching buttons. If not i’ll get the latching relay. I also grabbed some pilot light leds.
Ariel
Discussion Starter · #9 ·
What do i need to get for the trans fittings and lines? Is there a certain size fitting? What length cooling hose?
Ariel
Discussion Starter · #11 · (Edited)
Ariel
With this fitting to connect to the factory steel line
Font Line Screenshot Camera lens Camera accessory
You will want a 3/8 thread on quick connect not a tubing fitting.
Also don’t use that AN hose kit it’s cheap and the line falls apart and leaks.
these fittings is what you want
then get a roll of AN -6 and fittings from jegs using there brand stuff in steel line.
Ariel
Discussion Starter · #14 · (Edited)
Hows this look? Should I add anything else?
Font Material property Parallel Auto part Screenshot
I used the mentioned momentary buttons first with leds on the dash. Latching relay failed and I went with toggle switches. When using the toggles you won't accidently engage the buttons while shifting.
Automotive lighting Gear shift Motor vehicle Trunk Automotive tire
Handwriting Product Rectangle Font Material property
Motor vehicle Automotive tire Hood Automotive design Bumper
Circuit component Gadget Eyewear Audio equipment Communication Device
Ariel
Discussion Starter · #16 ·
Maybe I should get latching buttons with built in LED indicator and replace the momentary ones. I was thinking the relay may just add more stuff that could fail. I have to figure out what size button fits in the handle.
Buttons small enough to fit the handle can't handle the OD/LU current. The 30a automotive relays can..
Attached is the final rendition of my setup.
Hood Automotive lighting Motor vehicle Automotive tire Car
Reactions: Ghost03hemi
Ariel
Discussion Starter · #18 ·
Didnt think of the button not handling the current. In that case maybe I’ll stick to the latching relay set up. I found this one but it seems too cheap. I dont know what to look for in a quality relay.
Azure Circuit component Rectangle Font Screenshot
They look pretty much like what I used to build the module in the picture posted. Getting the wiring sorted out before the actual trans install will make the overall install much quicker. Get the shifter in and the oem linkage removed, neutral/start wiring ready along with the backup lights. You will be amazed at the difference the trans will make..
1 - 20 of 41 Posts
