1 - 5 of 5 Posts
Discussion Starter #1
I have a 06 2wd quad hemi. I’m replacing the front hub and I’m wondering what the torque is for the 3 bolts that attach it to the spindle. Thanks
Discussion Starter #4
I just changed the passenger side wheel hub. It doesn’t have a abs wire on that side of truck, only the drivers side has it. I figured both sides would have a wire.
John
No, some models have a front sensor and a rear sensor at the differential, others have 3 sensors, 2 up front, one at rear differential. You really only need one sensor in front, and one in the rear to calculate wheel speeds.
1 - 5 of 5 Posts
