1 - 6 of 6 Posts
馃崅How To Prepare Your Car For Fall
As it begins to creep into October, you know that colder weather is on its way. This means that it is time to prepare your car for the upcoming Fall and Winter seasons. Your car is negatively impacted by the cold temperatures in many ways.
Treat the Fall season as a time to prepare your car for the harsh chill that Winter brings. Cold weather makes it more difficult for your tires to maintain grip and makes the windshield more defenseless against cracks. What can you do to prepare your vehicle for the drop in temperatures?
Here are 10 Tips to Preparing Your Car For Fall:
1. Check the Belts and Hoses.
Look for cracks, leaks, and wears in the belts and hoses. You want to ensure that there are no signs of splitting, fraying, or glazing. One major problem with faulty belts and hoses is overheating. Although this usually occurs in the Summer, it can occur anytime of the year, including during the colder months. If you notice any problems with these car components, then you should take your vehicle to your local mechanic.
2. Check the Fluid Levels.
It is crucial to replace your car鈥檚 fluid levels, as necessary. This would include windshield washer fluids, transmission fluids, coolant, brake fluids, and power steering fluids. All are very important for ensuring that your car runs smoothly. Washer fluid is important for maintaining visibility. Transmission fluid is important for cooling. Coolant regulates the engine鈥檚 temperature, while brake fluid serves as a lubricant, preventing corrosion. Power steering fluid is crucial for operating the vehicle.
3. Check the Tires.
Check the tread, inflation, and overall condition of your tires. Rotate your tires, so that your tires wear evenly. Make sure your tire鈥檚 contain the appropriate amount of air. Maintaining proper tire pressure is very important, because cold weather causes tires to lose air quickly. Make sure you have the proper tires. This time of year comes with the potential of snow and ice. Consider if you live in a location where you need snow tires.
4. Prepare for the Cold Weather.
Getting stranded on the side of the road any time of the year is not fun. As the weather turns cooler, you especially need to be prepared for a roadside emergency. Be prepared if a situation like this were to occur. Stock your vehicle with the following items:
  • Gloves
  • Ice scraper
  • Blanket
  • First aid kit
  • Jumper cables
  • Flashlight
5. Check the Oil.
Change your oil at the recommended oil change interval. Consult your car鈥檚 manual to determine the recommended oil interval, as it may vary by manufacturer and driving habits. It used to be recommended to change your oil every 3,000 miles. However, this has changed due to the construction of modern engines and the use of synthetic oil. If your car has an oil-monitoring system, you can use this device as a guide.
6. Check your Heat.
Check to make sure your heat is working properly. You do not want to be without it when cold weather hits. Make sure the defroster works, as well. Driving with a fogged-up windshield is unwise and unsafe. If either of these components are in need of repair, take your vehicle to your local auto repair shop.
7. Check the Brakes.
It is important to get your brakes checked before getting well into the Fall and Winter seasons. Brakes are crucial for safe driving. Cold weather heightens brake problems, since the roads have the potential of becoming slippery from snow and ice. Listen for unusual noises that may point to failing brake pads.
8. Install All-Weather Floor Mats.
Consider investing in all-weather floor mats. These mats are long-lasting to protect your car鈥檚 floors against water, snow, dirt, and grime. These mats will even shield your car from stains and spills. They also do a good job for holding up against general wear and tear. You can use them all year long, not just in the colder months.
9. Check the Lights.
Take a walk around the exterior of your vehicle. Check to make sure that all your lights, including headlights, taillights, brake lights, and flashers, are working as they should. If needed, replace a broken or blown-out bulb. These lights ensure that other drivers see you on the road, even in bad weather or other conditions where visibility is low.
10. Check the Battery.
Check the battery for charge and signs of corrosion. You can even take your vehicle to a local auto parts store for diagnosis. Most of the time, this is at no cost to you. If you car needs a new battery, take your car to a mechanic to get your battery replaced. The battery is critical to start your vehicle.
馃巶 Happy Birthday to our HTC family with birthdays this week October 3-11!! Have a great day!!
馃 Welcome to our newest HTC members Zhender, the proud owner of a 2011 Hemi, and ZOtz2814, the proud owner of a 2004 1500. Great to have you on board!!
馃摳 Rocketman - Bill - has started a post "Remember when". It's been a fun post to follow. Check it out so you can "Remember when".
馃 Try your luck at being "Truck of the Month"!! Post a picture and a write up of your ride between the 1st-21st then we vote the 22nd. Thanks to Keith (charged392) for heading this up!
馃檹PRAYER REQUEST:
If you have a prayer request you would like to share either add it to this thread or PM me.
*MikeHTally - Kate's mother passed away
*Rancher - Doug general health
*Rancher's Lady - Mary
*Doc's mother -
*boedacres - Steve - health issues including diabetes
*SuperBee - John & his wife - health issues
*Those affected by the resurgence of COVID
Have a great week!!
Vertebrate Cartoon Botany Nature Leaf
Reactions: arocketman
Hi Nathan. How are things going??
Premium Member
Kima, life is copesetic. We have just never been this old. I knew that we would get old if we lived long enough but, I sure thought it would take longer. Been doing some long overdue cleaning out years of things that I saved because I will need someday, However, as happens sometimes, when .they are needed, they can't be found. Getting it done a bitt at a time. I work half a day then take two days to recuperate. We hope this finds you and Norris both well and enjoying life's pleasures. Have you seen any mention of any get togethers?
Say hi to Morris. Hope to see you again someday soon.
Nathan
We're doing great!! I really miss chatroom and being able to keep up with everyone.
No GTG's planned to my knowledge. Hopefully 2022 will allow us to have a rally!!!
1 - 6 of 6 Posts
