To edit your signature:
Click on userCP on the upper nav bar and then select edit signature" from the left side menu.
Add desired text to the signature editor and preview. If you like it, hit save.
To add badges to your sig:
Here is the page with all the images: http://www.hemitruckclub.com/sigpics/
Locate the image you want to add and then right click over it and copy the location (url) onto your clip board.
Next edit your signature in you user CP.
Click on User CP on the top nav bar. Select edit signature in the left side menu.
In the editor add any text you need and format it. Next place your cursor where you want the next image to be and then click on the "insert image" icon (looks like a mountain) with your mouse.
Paste the image link to the box that pops up and then click OK.
Repeat the insert process as many times as needed and then click save signature.
