1 - 20 of 325 Posts
The 56' Willys Pickup is at the point it is begining to go together. The last few months I have been dissembling it to see what I can salvage and honestly deciding if it was a resonable project or not. Last year I built a 6.1 stroker motor that should make big hp on pump gas NA. I'll use a spare 46rh trans. Actually communicated with Martin Saine today anout shipping it to him. Will use a 9.25 axle (narrowed) I got from a Durango, 3:92 gear. DTT differential. Big ford collars. I have most of the bits and pieces on hand. I knew I was going to build something but hadn't decided what it would be other than it would be Mopar drivetrain. So as of now it's a go...
Picture of the begining..
I can't wait to see it running
I'll certainly enjoy the major steps of the build. It is a great moment when the chassis becomes a roller. And again when the motor and trans are sitting on mounts. I enjoy the building and those various moments.
Here is a picture of the 4 link..
And here is the front... either could be used on a pro-street ram..
Discussion Starter · #11 ·
I'm waiting on the front, was told the coronavirus was causing a delay. Will be using 15" wheels and Wilwood brakes.
Discussion Starter · #13 ·
It's hard to stay motivated with everything thats happening. But I do a little everyday. Kinda hung up with deliveries at the moment but in the grand scheme of things hot rod parts are a low priority. Everyone pls stay safe...
Discussion Starter · #14 ·
About to start cutting up the frame and of course want to get it right. I don't have a frame table so to keep it square I'm thinking of building the new rails inside the old frame then cut away the old frame. It's a bit clumsy but that way I don't lose any references. Pictures to follow.
Discussion Starter · #15 ·
Pictures...
Discussion Starter · #16 · (Edited)
Another, I have a difficult time posting pictures.. mockup of frame joint..
Discussion Starter · #17 ·
Just called Summit and was told the manufacturer for the wheels hasn't responded to the quirey made yesterday morning. And Fatman is shipping the front tomorrow minus the rack. The supplier of the rack is locked down. I want the wheels/tires mount to get a good visual picture of what I have before assemblying the four link. So I'll do what I can.. no big deal...
Discussion Starter · #18 ·
I found this picture of a early Willys pickup that I like the looks of... I like it's stance, mine will have the narrowed axle and fatter tire but I hope a similar look.
Discussion Starter · #19 ·
Recieved an email from Summit telling me my wheels are on back order with an expected delivery of the middle of May. My guess is the supplier is waiting on a off shore manufacturer. I always feel taken advantage of when a supplier sells me something he doesn't actually have. I realize that is how business is done tese days but still doesn't feel right to me... Samething when I by an item and it comes in a Amazon box.
Discussion Starter · #20 ·
Recieved notification the fatman IFS will be delivered tomorrow. Worked on mocking up th four link today. The axle hangers are cut for 3" diameter axle tubes. (9" ford) called Fatman and told them I needed 3-1/2" diameter hangers was told they only have the 3". Truely a hot rod shop and not a race shop... disappointing but expected by now.. I think fatman started as a fabrication shop building hot rods. Became known and now mostly sell suspensions/kits.. The hot rods of my youth were cobbed together from junk yard parts assembled cheaply. Todays hot rods are assembled using highly engineered kits. Actually even kits are frowned on as crude and the underprivileged are suggested to use complete rolling chassis for their particular body. The underprivileged are anyone who's shop doesn't have a $20k chassis table... but in reality the old hot rods of my day were unsafe at best.. Fabrication crude by any standard, no brakes, poor tires and pitiful lighting... but damn they were a good time!
1 - 20 of 325 Posts
