Funday Sunday Feb 1st
11K views 123 replies 15 participants last post by  SUPER BEE
Planning to attend this one. Met a few local guys that are going as well. Don't believe any of them are mopars tho mostly gm, but still should be good.
#90 ·
I did lol. The track was all messed up. I'm damn sure I hit a 13.5 that run.
#93 ·
So, how was the drive?
#95 ·
You guys going to keep the numbers secret? So far all that's been said is a 11.9 with a truck that wouldn't hook.....
#97 ·
Lol I didn't get 11.9 but I bet that was a 13.4 pass
#98 ·
It would make for a better bet if you post the slip....
#104 · (Edited)
I have a few videos to load Mario made later tonight.
The cvi #'s in Mario's truck show little to no wear at all from install day on the clutch packs in the trans. so he is good to
Go with trans.
The monster was "Arocketman" truck. It does all the same stuff I had to tune out of
My truck. It's crazy to drive like bill has said it has grandpa mode and WOT mode no middle speed half has accel at all. It auto cruise controls. If your coasting along and put it in neutral it will rev on it's own. Etc. this
Needs some fixing badly. Trying to access his files but Arrington locked them on me even the base file. No bueno
#110 ·
Man, that tune sounds familiar......:whistling:
Just think about this Keith. High trans pressure only at wot with the oem computer and the 545rfe trans. Why would you want part throttle boost? It's just going to fry the trans. Arrington knows this. Unless you've figured a way to get high trans pressure at part throttle boost?
#107 · (Edited)
#115 ·
This is a question for you FI guys, wouldn't it make sense to use Dexron VI to reduce friction heat? If I understand this right ATF has friction modifiers to make a more comfortable shift by allowing the clutches to slip.
#120 ·
Gotcha... thks
