Fasthemiram05's 2012 Ram Build
55K views 690 replies 23 participants last post by  Ghost03hemi
#1 · (Edited)
Thought I'd post a thread of my build since everyone else has one...
Here are the parts I've collected so far....
1) 6.1 Intake Manifold (might change to Drag Pack)
2) JBA Longtube Headers (Titanium Coated)
3) 2 Dynomax 3" Race Mufflers and X pipe with Cutouts
4) ATI 15% UD Balancer
5) BBK Fuel Rails
6) AEM 320LPH Fuel Pump
7) FL TQ Billet Single disc Converter 2800 Stall
8) Dave's Big 90mm N2O plate
9) NYTREX Phat Shot Solenoids
10) Arrington 90mm TB
11) AEM Fuel Pressure and Wideband Guages
12) DynoTune Nitrous Control Center Guage
13) Black Catch Can
14) 6.4 Fuel Injectors
15) V6 Electric Fan
16) Diablo Intune
17) Line Lock Solenoid
18) PML Trans Pan
19) Sharadon Stage 3 VB
20)
21)
22)
23)
24)
25)
On the truck Currently is a Volant Intake, SRT shortie headers, and a belltech drop kit with drop shocks.
I also just finished breaking in 4.10 Gears and Detroit Tru Trac
As for the motor so far I have
1) 6.4 MDS Cam
2) PAC Racing Valve Springs
3) ARP Head and Main Studs
4) 6.4 Crank turned down to a 2.0 Journal 3.795 Stroke
5) Eagle Forged H-Beam Rods 6.125 Length .927pin
6)
7)
8)
9)
10)
Should be a fun build once I get going...
:dance:
#210 ·
Well... you know it's not complete already... It's also Blown as Nathan was running some high hp numbers.
I didn't receive it with a vb in it and I'm not gonna buy one for a blown trans
#221 ·
These are the specs on the Turbo:
CXRacing Ball Bearing GT45 80mm Wheel Turbo Charger
Stage III Ceramic Ball Bearing on Compressor Side
Anti Surge Turbo Inlet with Vband Oulet
1.15 A/R Turbine Housing For Super High Exhaust Flow Motors
T4 Divided Flange to Manifold
V-Band Downpipe Flange: 3.5" ID (Fits 4" Vband Flange)
Turbo Air Inlet: 5"
V-Band Turbo Compressor Outlet: 3.25"
This is a High Performance High Output Ball Bearing Turbo. We Have Dyno Tested This Turbo with Our LS1 Turbo Kit on a 383 Stroker LS Motor (Stroker 5.3L Truck Motor), It Makes Close to 900 HP at 15PSI
#229 ·
Who says this is addictive?
#233 ·
I myself, have been doing some turbo searching. However, when I do the calculations it always comes out with recommended turbos ranging from 94-108mm. Why are we running 70-80mm on bored and stroked motors? It seems as though if toyota 2jz's are running 70-90mm with is only 3.0L, then the calculation we should be 94-108mm because we're double the displacement, don't seem to far off. Just curious. Any wisdom on selecting a proper turbo would be great. Thanks
#234 ·
It's the back end that really matters that's where most of the flow is critical. The boost side you normally want in mm as close to the boost piping you will be running in a nut shell. The AR of the exhaust will determine how fast the boost comes on along with the exhaust setup and motor cubes. It's seems complicated its really not.
On v8 eng generally 60-76 are fast spooling turbos 77-whatever takes longer and the AR on the exhaust plays a big part.
#236 ·
It's the back end that really matters that's where most of the flow is critical. The AR of the exhaust will determine how fast the boost comes on along with the exhaust setup and motor cubes. On v8 eng generally 60-76 are fast spooling turbos 77-whatever takes longer and the AR on the exhaust plays a big part.
:thumb::thumb::thumb:
#235 ·
Got this sweet Methanol Controller yesterday...
I didnt even realize the great deal I was getting till I saw the in cab controller.
#242 ·
I don't know the details of all these parts. but this all sounds to me like some really good deals being thrown around.. Florida rocks...
