Fasthemiram05's 2012 Ram Build
55K views 690 replies 23 participants last post by  Ghost03hemi
#1 · (Edited)
Thought I'd post a thread of my build since everyone else has one...
Here are the parts I've collected so far....
1) 6.1 Intake Manifold (might change to Drag Pack)
2) JBA Longtube Headers (Titanium Coated)
3) 2 Dynomax 3" Race Mufflers and X pipe with Cutouts
4) ATI 15% UD Balancer
5) BBK Fuel Rails
6) AEM 320LPH Fuel Pump
7) FL TQ Billet Single disc Converter 2800 Stall
8) Dave's Big 90mm N2O plate
9) NYTREX Phat Shot Solenoids
10) Arrington 90mm TB
11) AEM Fuel Pressure and Wideband Guages
12) DynoTune Nitrous Control Center Guage
13) Black Catch Can
14) 6.4 Fuel Injectors
15) V6 Electric Fan
16) Diablo Intune
17) Line Lock Solenoid
18) PML Trans Pan
19) Sharadon Stage 3 VB
20)
21)
22)
23)
24)
25)
On the truck Currently is a Volant Intake, SRT shortie headers, and a belltech drop kit with drop shocks.
I also just finished breaking in 4.10 Gears and Detroit Tru Trac
As for the motor so far I have
1) 6.4 MDS Cam
2) PAC Racing Valve Springs
3) ARP Head and Main Studs
4) 6.4 Crank turned down to a 2.0 Journal 3.795 Stroke
5) Eagle Forged H-Beam Rods 6.125 Length .927pin
6)
7)
8)
9)
10)
Should be a fun build once I get going...
:dance:
#390 ·
Well... Dropped it back off at the machine shop again.
Found a cam bearing slightly off with about 25% of the bearing covering the oil passage hole. Also cam didnt turn easily.
#393 ·
Did you clock the rear oil hole at 5 o'clock? What are your thoughts about doing this?
#397 ·
Well.. Picked up a new cam for the build.. Not gonna use the 6.4
Gonna use something different.
Its a secret so dont ask.
I truly want to be the first to use this cam
#400 ·
Ahhhh the best way to keep a secret is not to tell anyone there is a secret to begin with. You're busting to tell..... lol
#405 ·
#409 ·
Finnally figured out what was wrong... Crank was ever so slightly bent. Put it on a crank bending machine and its spins true now. No drag when it spins in the mot either.. Will finish short block this weekend
#411 ·
That happens more often then folks would guess. A simple roll on the floor will bend it. Well done in catching it.
#412 ·
My wife dropped mine twice on its side from standing straight up. Luckily I put it in had a small grab took out and got lucky found tiny ding on edge of main journal on crank filed of spun smooth. Figured she may have made a $1000 mistake got lucky myself
#423 ·
That certainly looks different...
