1 - 20 of 20 Posts
need some advice for 06 ram hemi
i ve got no resonators and flow super 40 2.5 dual out. had the 50hd on same way just swapped mufflers. the 50 had better trottle response but not the sound i wanted, thats why i swicthed. seems the super 40 is opposite, little more sound but honestly wasnt much but trucks sluggish now
also i order the at3030 and y pipe to hook the tailpipes back up and thinkin of another for after the cats but not tryin make it crazy loud(wife)but have people know it around
and is it a 1500 or 2500? Check out the exhaust section further down the page ALOT of write ups there of what people have tried and liked and disliked and why.
its 1500 and i have read a ton on at3030 and 3030xl. just curious on how loud itd be with y pipe no resonators dualed out. what ive read, alot got it dumped or with rear resonator This message has been edited. Last edited by: allen2, document.write(''+ myTimeZone('Mon, 01 Feb 2010 03:16:51 GMT-0800', '01 February 2010 06:16 AM')+''); 01 February 2010 06:16 AM
Welcome aboard allen2 - we're glad you joined us!
Check out the exhaust section below. I just uploaded a bunch of videos of my set up. You will see my thread and the progression of what set up I ended up running with pics and then on page 2 of the thread the videos I took yesterday. In a nutshell I have an 04 QC HEMI running stock exhaust manifolds, stock cats, then ran extra pipe to the aero turbine 3030xl. We attached 2 magnaflow y pipes right to both sides of the 3030XL. So dual pipes all the way back to the muffler/y pipe set up. The duals right out of the muffler out the back behind tires.
The rest of my results are in the thread.
Good luck.
i think i did see your setup what would the difference be if y pipe is right after cats? but yours does have sound i want. there any performance changes?
I dont think you will see any real huge performance difference in my opinion. The installer, who used to have a HEMI and is a member here, decided to give it a try the way we did it. It's almost as if we are using that 3030XL as a merge for the dual pipes coming into the y pipe right on both sides of the muffler. Just something different. I havent seen it set up this way on here or Dodge Talk. I think running the 2.5 pipe all the way back to the magnaflow y pipe and then 2.5 pipe out the back made the difference for sound and response.
I have heard from a few that the 3030 and the XL version sometimes caused a "Slight" lower throttle difference with the 3 inch in and out. I have seen people running the y pipe after the cats then 3 inch pipe section to the 3030xl then single out the side. Some claim a bit less responsive. I actually noticed an increase in response and what seems to be a better shift. Depending on how I drive it, it shifts smoother and snappier. Just my observations with the set up.
Oh and I am not running any resonators at all.
Discussion Starter · #15 ·
i was plannin that too. but also tryin not to piss the wife off, so i dont know if i should do how you have it or add a resonator. i got a 3030 comin today or tomorrow and was plannin to send it back for the xl. yours noticable cruisin? and loud when on it.
Discussion Starter · #17 ·
i havent seen many with flow super 40. another route i was fixin to take is leavin the 40, addin magnaflow hi flow cats with y pipe, see if that would make louder sound and performance. but im not impressed with flow on this hemi at all.
Yeah its nuts trying to find a balance and I believe there is a certain balance but difficult to find. Good luck, my wife says "as long as your happy" and "on our next trip I will have my iPod to listen to with earphones" So if that helps
Yes its noticable while cruisin. From about 1700 to 2000 there is a little drone in the cabin. We moved the muffler back past the cab as far as we could and there is still a little drone at those RPM's accelerating. Once in OD its not that bad, but I enjoy the sounds, others may not. I would say 50-60 mph there is drone and once above 2000 around 65-70 drone isnt bad at all and actually dissapears, unless traveling uphill. Personal preference I think. When on it oh yeah....it screams...
Others I have talked to say the same about their FM's. They changed to MF's AT's or something else. Again I never had one so I can't judge, the FM's just didnt have the sound I was after.
Discussion Starter · #19 ·
im in that boat. thanks buddy, you and your truck have been big help. just still somewhat undecided. lets see if anyone can give me more insight. youll probably hear back from me
No worries and there is a TON of help here. Great folks and they have tried or helped many different things and people.
Good luck
1 - 20 of 20 Posts
