61 - 80 of 90 Posts
I switched from I. E. after they said this website wasn't working correctly. I now use Google Chrome, & I had absolutely NO trouble opening this website, as you can see. :thumb:
Chrome blocks links opening from Outlook. Back when I did desktop support, it sometimes took a whole day to get rid if that problem. We had to weed out every mention of Chrome in the registry. Mainly the problem was allowing Chrome to become the default browser.
Matt
I haven't had any problems at all. I've been running firefox as the default browser since day 1 with this computer. Granted it's only about a year old but with my last one that I had for 4 years before lightning sent it to an untimely demise I never had issues either. Set up the same way. Only difference is my new computer has windows 7 and my old on ran on vista.
Matt
Gold-Member
Discussion Starter · #68 ·
weird in chrome I was getting a ton of ads popping up by ad coupon dropdown. I closed that and opened IE and they are all gone. gotta do something there.
Keith, you have been to a sight that has added a program on your PC from Ad coupon. Or you downloaded something and didn't read the permissions box and uncheck it. i had the same thing. Go to your add remove programs and search the list for Ad Coupons and just do an uninstall. Then you need to go back into your settings for Chrome and delete the other browser options from the list. It worked for me. No more popups.
And to everyone else that isn't seeing the side bar ads, it may be because your not using a very big monitor. The ads are only in the side bar space to fill in. i run (2) 22" monitors that's why I have them. On my 17" laptop they are not there.
Gold-Member
Discussion Starter · #70 ·
It's not the site. It's something that's on the comp that's having issues. I deleted snapdo kinda looks like
Google and I'm good to go now no more adds. The trick is finding what is causing the pop ups and what not to show.
Gold-Member
Discussion Starter · #73 ·
we're still having problems. tried two different virus programs and still having problems. we're tired of messing with it. can only post up using my phone. just not going to post up that much anymore.
Stu, like Keith said, there is a program on your PC that is allowing or generating the pop-ups. I think it gets loaded when we click the X on the banner at the top of the site trying to close it, Tricky bastards. :facepalm:
Go to your control panel, then Add/Remove programs and look through the list for "Ad Coupon, and or the one Keith mentioned. remove them and you should be good. Mine is now. Good luck.:thumb:
Did you try anything other than what I posted?
It's been a while since I have cleaned up any computers. There are many variants of spyware/malware that cause popups and such. You may find some needed info in these forums.
Security Forum - BleepingComputer.com
SpywareInfo Forum
https://forums.malwarebytes.org/
Malware Removal - MajorGeeks Support Forums
Gold-Member
Discussion Starter · #77 · (Edited)
Going forward,
I use Kaspersky antivirus software it is the absolute best. I had a friend that does PC forensics for his business. Ch.2 over in Orlando got hit really bad with a very nasty virus. 1200 pc's got hit. He set up 20 different computers in his shop with the virus files on them. He then installed 20 different antivirus software programs. One per. This virus was so nasty it would change its location, and even change its name when the programs or a person would access the folder it was in. He said only 3 of the antivirus programs could find it, and of those, only 2 could quarantine it. Kaspersky was the only consumer, Non professional, aka-expensive ones that could stop (quarantine) it. (None could delete it) he needed to write a custom code to delete it form the computers.
I have lived by Kaspersky ever since. And have never had a virus.
That being said. Nothing can stop a program from loading on your PC that you have given permission to load. Be it through another program asking for permissions and piggy backing adware on with it. You need to be sure to read all boxes that open up when you are loading legit programs. and un-check anything you do not agree with.
Some other things I use to keep things clean is:
1)Advanced system care Pro, by IObit. It keeps things like your cookies, registry, temp files and bunch of other things cleaned up. Thus helping the PC run like new.
2)I also run Malwarebytes once a month to look for malware that may have gotten by the other programs.
Nothing is a guarantee when it comes to PC's. But I have found this combo works along with staying very diligent and making sure to read every pop-up that you get when you are loading a new program, and be sure to not just click yes on everything.
Hope this helps some one with the headaches of resetting everything on your PC every few months.
Thanks David. At one point, April did get everything straightened out. Went to check my email and couldn't get logged in for some reason.:confused: April set it back up and then all kinds of things popped up on the site when I went to log in.:doh::doh:
April did get it all straightened out again. :smitten: So far, no pop ups.
Gold-Member
Discussion Starter · #79 ·
What do you use to get your emails?
Kaspersky is a good one. The thing about av and malware programs is there is not a single one that works for everything out there. You have to use a variety of them to find everything that is known. Like the old saying goes: never put all your eggs in one basket.
I just worked on a laptop that a colleges IT guy scanned and found nothing. He found nothing because the hard drive has bad sectors and needs to be replaced. Sometimes it's hardware related.;)
One tool I use that I do not recommend for many is hijackthis
61 - 80 of 90 Posts
