1 - 4 of 4 Posts
08redhemi
Discussion starter · #1 ·
2008 ram 1500 5.7 hemi non mds 160k miles
having an issue where engine is misfiring at idle, can feel it running rough also getting P0306 code (cylinder 6 misfire) so i swapped the coil packs from 2-6 cleared the code and the code stayed with 6. plugs all have about 10k on them pulled both plugs from 6 and 2 and all look the same, put 1 plug back in each cylinder and did a compression test 150 psi on 6, 180-185 on 1-2-4-8, i know 30 psi is enough to cause a slight misfire but im not sure where to go from here to find what is causing such a slight compression loss. thanks in advance!!
1 - 4 of 4 Posts
