It's the rpm range of the cam. You would need no less than 4.56 gears, 4000 stall Tq converter, and 7000rpm shift points to use a cam that size.What makes it too big? If you have valve springs to handle the higher lift, and added duration why is it too big?
Our stock heads flow a good bit, and make decent power on very mild sticks. You would think, in theory, it would make great power.
I agree. I ran the Comp 268 on my old 5.7L with 4.56 gears and a 2500 stall. It performed well with that setup. I have never heard of someone running the 274 in a truck.It's the rpm range of the cam. You would need no less than 4.56 gears, 4000 stall Tq converter, and 7000rpm shift points to use a cam that size.
Here you go.......What's a phaser?
The title of my post is wrong big deal, but still no one has any concrete information?
Sorry you feel that way, when you are older you might appreciate help when given.... or maybe not. good luck..seems like a majority of people on here don't know anything, and the few that do don't even post anything.
No, but you do have to be a member of Star Fleet to get oneHmmm do you need a permit to carry that?
