Well I had a thread about doing a cam swap, now that is over, time to re-start all over again and do it right! I do it nice, cause I do it twice! :rofl:
I had really wanted to do a stroker kit the first time around, but time and financial constraints weren't allowing me to. But after I found out the fresh rebuild was burning major amounts of oil in cylinder 1, I decided to just go for it. To start the process, I chose to get a used 5.7 block and build the stroker first. When its all completed with the necessary machining and installation, I'll pull my old engine out and swap over the heads and accessories. I've already added a Comp 260, new valve train, torque converter, oil pump and timing set the first time around, so I have a good base to start with. So after a bit of searching, I found a blown engine at a local junkyard for $400. They didn't have any info on why it was blown or the mileage, but I figured I would be only using the bare block and it would be over-bored to begin with so it couldn't be too bad. Any other usable parts would be experimented with or sold to help recoup the cost. After pulling the heads I found the reason it was blown, cylinder 6 had no piston head left, it was completely blown out with just the rod and wrist pin left. So I will have to have one piston re-sleeved, I don't think that is a big deal in the end. Other then that, all the other cylinders are at standard bore size and should clean up well. At this point I have the engine stripped to the bare block, tomorrow I'll start with the wire brush to remove all the old paint and rust. Then it will be sent to my local performance shop to bore it out and get it re-sleeved.
I plan on using the SCAT Modern Muscle Stroker Kit from Summit Racing. It's in my price range and comes balanced. So feel free to pitch in any suggestions or tips!
