Change diff fluid and found...
1 reading
1.8K views 14 replies 6 participants last post by  Redtruck-VA
Changed my diff fluid last night (Amsoil 75w-90), when I cleaned the diff out i found this..
I'm assuming these are clutch pieces from the lsd since the gears look fine...
#2 ·
#3 ·
The limited slip won't last forever especially with the power you're pushing.
Now will you get a detroit locker?
How about a picture of the gears?
#4 ·
didn't have my phone with me when I was underneath, I rolled the wheels an watched the gears rotate...they looked good. I know an adjustment has to be made because when it comes down from 3rd to 2nd the is a clang in the rear end,,,
#6 ·
those look just like the plates that go between the clutches. I am sure you could get a rebuild kit if you wanted to but it will just happen again.
I think its time for a DTT or something else.
I am happy with my Auburn but it may not be good enough for the racing you do.
#8 ·
I think he had it rebuilt once before at around 100K. Even still he got his money's worth.
I hope he finally puts a full locker in that beast. He'll hook up better at the track and get out of the hole better.
#9 ·
it's actually the original lsd...still runs fine but I know I need to replace it...am looking at dtt's though, anyone know best price to find it?
#11 ·
That's a limited slip Fred.
You really want a full locker.
http://www.summitracing.com/parts/DTL-187C172A/
Just got to be a little careful around corners in the rain etc. Otherwise there is no downside and all plus's for the track and they way we all know you like to drive.
#12 ·
#14 ·
Originally posted by chefred112:
ok, so now im leaning towards the locker now..waitn to see what Eddie can get it for..
It doesn't get better then that.
#15 ·
Fred, i ran a locker a long time ago and it would point the truck a little under partial throttle. Not really what you want under some conditions. I now use a DTT in Redtruck and it works flawlessly. It locks instantly with no side effects. Plus it looks like with the price from Summit being over $500 you will get $50 back.
Good luck..
