41 - 60 of 153 Posts
Anybody I can talk to that could help me?!? Trying to get a 6800-7000 rpm redline:)
Call 1 866 844 1245 and ask for Greg. Explain to him that you have a 03 Ram and you want a companion tune that can be CMR tuned by your own tuner. Tell him the idle, top speed and rpm you want everything set to. Get the mailing address, and mail in your PCM following Greg's instruction. You might consider buying a spare PCM and have them flash it along with your VIN so as not to get caught in a jam. Good luck..
Be patient, it took me three attempts to get it right.. good luck.
Niiiiiice!:thumb::thumb::thumb:
Keep in mind the companion tune is nothing more than setting the basic parameters of idle, top speed and rpm limiter. And you will need your CMR tuner to tune for performance.
It's unfortunate that ARP bolts are so expensive. But you really do get what you pay for with their product.
The OEM bolts work just fine, though. Obviously. Which is why using ARP bolts for the crank, and cam is pretty much a moot point. Unless you have the extra cash laying around.
Good luck, my starter motor has been out for delivery for 5 days.....:(
Bam! Matt said Monday for the delivery of the pulleys by the way, so we should know something pretty soon
