Blinking ABS light after tire size adjustment with Diablo
15K views 89 replies 9 participants last post by  Redtruck-VA
I have an 03 Hemi Ram with the ABS light blinking after the tire size adjustment with the Diablo Preditor tuner.
This is a continued discussion from the Megasquirt topic. http://hemitruckclub.infopop.c...0068252/m/9291057246
Truck info:
03 Dodge Ram QC SB
Forged 5.7(348) 9:1 CR
KRC210(RV)cam
Manley valve springs, push rods and valves(OEM size)
SRT4 injectors
SRT4 2bar map
Front mount T76 turbo
Twin 38mm W/Gs
50mm BOV
Front mount air to air after-cooler
Snow Performance stage II W/M kit
Twin OEM fuel pumps, 50psi steady fuel pressure(each pump feeds one side of the fuel rail)
KRC 5psi boost mild street tune
DiabloSport Predator U7137.(Stock rev & speed limiter settings)
4" full length exhaust with diesel straight through performance muffler
Edge 2800 stall T/C
Sharadon stage III trans
Trutrac Posi
4.56 gears
Caltracs Traction bars
442rwhp/487rwtq with 8psi boost.
488rwhp/534rwtq with 10psi boost.
13.18@105.83 with 8psi boost, full street trim and OEM 20" wheels and tires(275/55/R20).
Preparing for 10psi boost track run in full street trim.
NOTE: Had NO problems or adjustments done with this tune since 4/8/09.
The reason for the tire size change was due to the truck hitting the speed limiter just before the end of the track(105mph). The engine was also hitting the rev limiter(5800rpm) at each trans shift point. Was told there would be no problems with adjusting the tire size to possibly hold off the speed limiter at the end of the track. That's when the ABS light started to blink after the tire size adjustment.
#85 ·
Any plans or update?
#86 ·
Updates?
#88 ·
I'm betting the abs module just needs a reprogramming by a drb3 like my truck did when I put the new comp in it and when they do it doesn't change the PCM at all but before doing anything save your tune on the computer
You can hook your predator to your pc in the house now and extract last tune writin and then you will have saved your current PCM tune to the computer for safe keeping
#90 ·
On the very odd time I've had to go to the dealer (ABS reset) I always removed my tune, even if it was in the parking lot.
