So here's my thought process.. Soon as I get just a tad below half tank of gas I am experiencing a fuel pressure drop causing the engine to hesitate from lack of fuel. If you look down in the tank you can see a sump that is molded in the tank where the basket sits down inside..So by modifying the fuel basket with a hole in the bottom, allowing the fuel pick up / filter to stick out of the bottom in that molded sump where there should always be a puddle of gas, so now when the fuel starts to slosh to the back of the tank the fuel should rush into that molded sump and up inside the basket, my fuel return line is also down in the bottom of the basket to help fill that sump . With the filter / pickup pointing to the back of the tank it should be in fuel.. That's my thought process..... If this does not work the only other thing would be a baffled tank. At this point I have nothing to lose but sometime experimenting, testing a theory.....🤞
