1 - 4 of 4 Posts
Here’s a link to the mopar connector repair website:
According to the mopar connector repair site it shows both 1 & 3 as empty:
Here is some more info I found browsing the web:
The "connector change" was actually for 2011 MY, and although the color of the main solenoid connector changed (the physical connector was the same), the real change was the removal of the OD solenoid. So a 2011 or later solenoid module (or valve body assy, or transmission) will NOT work in a 2010 or earlier truck.
Would you happen to have a wiring schematic? I’ve been looking online for 06’ and it seems like the 06’ are the black sheep of the family. I’ve converted to an 46RE transmission. Those whom have done it had the old style plug. I need 12v value, neutral and back up lights. I believe the back up lights are given reference for TRS but I can’t seem to find which one. Would you happen to know if the 10pin is a 12v supply?
did you ever get this worked out ? I did an 06 a few years back, when I did my research on it I based it all off of what factory for the 4.7 Manual trucks.
the SRM and Wiring Diagrams can be found here.....File is too large to attach
18 Dodge Trucks Service Manuals Free Download
Also FWIW here's a like to the connector page
1 - 4 of 4 Posts
