Anyone got a stock 03-04 tb
9.7K views 110 replies 11 participants last post by  ATXHEMI
Want to do some experiment with it trying to port it myself
#86 ·
This is a weird one for sure it has to be something in the connector broken wire or loose pin since it worked before and now both tb are inop and non responsive
Do you know how to disassemble the plug its a bit tricky and if not done correctly pins won't stay in it when done then you would really be SOL I wish I was closer you need to check for a damaged wire it's likely I'm sure in your struggle to unplug it damage happened
#90 ·
#100 ·
That's because you reset the adaptive's back to square 1. Also your running on a canned tune. If you had a custom tune it would run alot better from the start. It's not a fail, just a bump in the road of modding. There's probably nobody on here with a modded truck that isn't saying, yep been there done that, on atleast one of their mod's. lolol
