1 - 2 of 2 Posts
Hi all,
Seems my coolant pump has crapped out and the belt has helped spray coolant on just about everything including the alternator.
The battery save mode has come on since the coolant spray. I had the battery load tested and the battery is good.
The question is…. Will the alternator start charging normally when it starts to dry out. Pump is getting fixed in the am. Thanks in advance.
Sometimes it gets inside and ruins it won’t know till it’s back up and running to be sure unfortunately
1 - 2 of 2 Posts
